Lining up Transmission Input Shaft, Pilot
I'm having a lot of trouble getting my transmission installed. it slides on with only about a half inch gap all the way around, followed by a clunk. we've wiggled it all kinds of ways and it doesn't want to line up.
To be clear, the flywheel is the same size as stock, the pilot is pressed in flush with the gearbox side of the flywheel, the clutch disc is installed properly as far as I can tell. I hammered a 10mm deep socket (fits pilot) and a 15mm deep socket (almost fits clutch disc splines) together and they slid right in and even felt centered, so I don't think it's a clutch alignment issue.
I've been told not to use the mounting bolts to pull it onto the engine, so I'm at a loss for what to do. Has anybody run into this before, and what do you suggest?
MiniMan
Audi Original "S" Cars
05-16-2007 06:14 AM
EuroTrasher
15
04-01-2006 02:41 PM
por911
10-27-2005 05:39 PM
AndrewsQuattros
12-05-2003 05:51 AM
Jeff Doble
04-30-2003 06:46 PM
