LLTek Cat-Back Exhaust
I just had a complete cat-back system done custom at the local exhaust shop for under 500 bucks total. What model are you looking to install it on?
Mine included dual glass packs, custom 2.5" pipe, magnaflow mufflers and SS tips. Do the valence mod yourself - it's pretty easy. Easier than getting rear ended like I did![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
I posted some pics on monday of my new setup. Go back a page or so and check em out.
Looks really great. How did you get hooked up with the shop? Also, it looks like you eliminated the center resonator/muffler. How is the sound?
<center><img src="http://pictureposter.audiworld.com/19134/xtek-quality.jpg"></center><p>Fit was bad, they basically laughed at me when I showed them this picture and questioned the quality.
Hard to go after them in Canada "EH".
As for the shop, I had some work done on my previous K5 Blazer there. Also I asked at the shop that works on my car, <a href="http://www.matrixengineering.cc">Matrix Engineering</a>, and they reccommended them as well. I stopped in to chat and we put it on the lift. Got a good quote and went for it. Seems around 350 with no resonators is a decent going price. The tube bends were real nice, and the stock pipe was only 2" I believe, so I got an upgrade to 2.5". They also made fittings to hook everything to the stock hangers.
If you search around here, you'll find loads of on muffler brands, MagnaFlow is a fairly popular choice and lifetime warrantied. DynaMax was an option for a few less dollars, but the MF's had a better fit.
Your 2.7t will vary from my 2.8. Turbos can get by without the resonator, and good mufflers will give you a nice sound. On the normally aspirated models, a resonator helps reduce the drone. I did add a balance tube before the glasspacks to equalize the levels(cheap) as opposed to the x-pipe which would be a bit better but another 120.
I definitely get a bit more drone by changing from the stock resonator to the glasspacks. I kept all my parts though, so if it gets annoying I could put the stock resonator back on while keeping the Magnaflows.
If you're going to spend the cash, do a couple searches for specifics of the 2.7t. Lots of people upgrade without buying expensive kits.
kish4
30v V6 Discussion
10-30-2006 04:53 PM
TeenA4Driver
07-24-2002 02:15 PM
T-28-Quattro de VT
09-05-2001 03:51 PM
