Looking for 6-speed wiring and plumbing bits
If anyone is cutting up a 2.7T 6MT wiring harness, I need the following pigtails:
Clutch interlock switch (bottom of clutch pedal travel)
Vacuum interrupt switch (top of clutch pedal travel, next to brake light switch)
Reverse light switch (2-pin connector plugs into top of transmission)
Also looking for a clutch master cylinder feed hose (runs from top of clutch master to brake fluid reservoir) and two spring clips, one each to hold the clutch hard line to the master and the slave.
eigenvector
10-30-2006 06:51 PM
