Looking for stock springs (or as close to stock height as possible)
Old 11-25-2011, 06:26 PM
  #11
n3985's Avatar
I have my OEM Avant springs for sale, in Avant the rear springs are stiffer to compensate for cargo. I am local too, just throwing this out there in case you can't find sedan OEM springs for sale.
Old 11-26-2011, 04:28 AM
  #12
jedblack's Avatar
PM Sent...
Old 11-26-2011, 05:19 AM
  #13
Just Me's Avatar
your logic is good, but i still find it odd that springs sagged. They very rarely do.
I've run audis nearly 300k with stock springs.
Old 11-26-2011, 05:41 AM
  #14
jedblack's Avatar
Agreed, its not like the body is down to the floor. I still have wheel well gap (probably around 3" overall) -- its just that the rear is riding lower then the front height. Thats is what makes me think they need to be replaced.
If anything the rear's should be higher then the front since its suppose to carry a load.
maybe i'm just crazy or over-analyzing it too much...
i'll try to grab a photo of the car, so at least some other can have a look -- definitely dont want to spend more money then needed.
Old 11-26-2011, 11:08 AM
  #15
jedblack's Avatar
so...am i just nuts, or does the rear appear to be sagging? seems like the front is sitting higher
Looking for stock springs (or as close to stock height as possible)-capo8.jpg
Old 11-26-2011, 11:17 AM
  #16
n3985's Avatar
My Avant looks the same, and we have the same color!
I envisioned the rear of the car sagging down as if fully loaded with cargo.
Old 11-26-2011, 11:23 AM
  #17
jedblack's Avatar
ehh... ok, that settles it -- I guess its just an optical illusion. If i wanted to be really **** about it I could measure the ground clearance of the front and back. However, if yours looks the same... then thats fine me....
can direct that limited dough towards something else... like two ultra expensive catalytic converters... :-(
se la vie...
Old 11-26-2011, 01:49 PM
  #18
Just Me's Avatar
looks about right to me. The styling does play a slight trick as you note.
(I have an S6)
Old 11-26-2011, 01:54 PM
  #19
Just Me's Avatar
Let's get objective. I just went and put a level (ok, ok, an iphone) on the door sill where it is flat. The bubble was more of less centered. Is yours? Of course, you must be on a level (poured concrete) surface to do this.
G
Old 11-26-2011, 03:05 PM
  #20
SloopJohnB@mac.com's Avatar
Interesting...I used an iPhone clinometer app (bubble) and it came up within .1 degree of the floor reading.
Quick Reply: Looking for stock springs (or as close to stock height as possible)
