Loose steering rack bolts on A6?
Per other posts here, I took my battery out of my 2000 A6 avant 2.8 thinking there would be bolts under it to tighten up a loose steering rack, but found nothing.
My steering is clunking when you first turn the wheel and it looks like the loose rack bolts other posts have described and fixed by looking under the battery?
So...How do you check/find the rack bolts on an A6 Avant...what did I miss here?
Thanks!
Thanks!
Mo betta jack front up and hold tire 10-3 and shake...look for CA movement.
This link is for a B5 A4, but I having done a rack on my C5 A6 2.8Q. I have found it to be the same. The two top bolts are easy to get to, the third might be the hardest bolt I have ever had to get to. The one under the battery is under the raised base for the battery.<ul><li><a href="https://www.audiworld.com/tech/misc-40.shtml">https://www.audiworld.com/tech/misc-40.shtml</a</li></ul>
S4MarkS4
09-05-2006 09:48 AM
On A6 95-97 the steering rack is mounted via 8mm or 10mm bolts. How to find what bolts are used on .
beep-beep
Audi 100 / A6 (C4 Platform)
06-20-2005 10:18 AM
Pizzicato
03-23-2005 11:23 AM
Clues
10-21-2003 05:12 AM
