Lower temp thermoswitch for A6 after-run system
I've seen it written that ECS has a low temp thermo-switch, but don't see it in their catalog. Anyone know if they have it, or where else to get it? Thanks.
Kevin
Kevin
so just by adding this switch the car fans runs after i shut the car down?....plus...
i have the green temp switch will the blue one work on my ride? also i though you should not change it from stock when it come to the temp - affects the gas usage..
Yes. Afterrun thermoswitch is different from the thermostat
It controls at what temp the afterrun pump/fan operates when you shut off ignition. Provides coolant to turbos - good.
Afterrun pump will also go bad quicker...
Without the lower temp thermoswitch, the pump/fan will never run after car turned off - setpoint is TOO high...
