M.P.G. and coolant temp sensor
I had a post a few weeks ago on my fuel mileage going down and my car flooding.The response was more or less cold temps and short trips, car always in rich mode. This made since but the car never felt right. I was looking on the S4 forum on found a post on the coolant temp sensor that listed all the problems I was having. I went and bought the parts 059-919-501-A (sensor) and N-903-168-02 (seal) 5 min. to install and $6.19 in parts and the car is a new car again. Must have been in rich mode all the time.
ggibson, if the outside temp drops and or your state is using a petrol additive like MTBE, then your mileage will go down some. You did not post year or mileage of your car , but the state of tune of your car matters as well. You may want to check the condition of your o2 sensors. Usually, as they go bad , the sensors send a signal that makes the inj go rich instead of lean.
I dont dought the mileage will drop off in the winter but this was 3-4 mpg. I did pop a few temp codes. The car didnt seem right. I thought it was in my head. After replaceing the temp sensor it run a whole lot better. Amazing what you get use to. I am in Michigan and the car is a 01 2.7t
