Manual rear sunshade clip
How is your rear sunshade clip secured to the headliner?
Mine are just clip in place and comes off from time to time.
There is a small hole on the clip but is too small for any
fastener to go thru. I am thinking of using some glue to
hold it in place. Any suggestion?
I had the same problem. I applied a small amount of silicon cault to the top edge of the clip right where it contacts the rear window. This has worked quite well as the clips no longer come loose. Also, clear silicon caulk is great because you can cut it and peel it off and it will leave no marks.
--Ira
--Ira
