Manually moving a stuck power seat? - Help please
Audiworld Senior Member
Is there any way to do this? Bentley says move the seat full back and up to remove it. Of course it is stuck full forward. Impossible to see under it let alone find the longitudinal motor. It is either a bad memory module or a short in the wiring. 03 A6 Avant power driver seat with memory.
Thanks in advance
Thanks in advance
AudiWorld Expert
You probably just moved it forward enough to unhook the wiring connector, which has happened to a few people I know that have the A6. I am assuming that there is no power to the seat at all, and you cannot even move it up, right?
If the seat is high enough, can you reach the two bolts that secure the seat to the car? Look at this post to see the bolts I am talking about: https://www.audiworld.com/forums/sho....php?t=1693961
If so, then remove the bolts, which frees up the front of the seat, then just tilt up the front edge of the seat and slide the seat back in the rails manually, reconnect the wiring harness (the red one has teh power), and then use the seat controls to move the seat back all the way. Then just re-align the front to bolt the seat down, and you should be fine. Just remember to not move the seat all the way forward again.
AJG
Black Sunshine
02-24-2022 02:32 PM
ondo
05-07-2003 10:15 PM
bimmerslay'r
04-24-2002 08:19 AM
