May I ask a favor from owners of Bentley manual?
I would appreciate a pinout diagram for ABS controller connector if it is appropriate to share such information. Mine is '99 2.8. TIA.
The reason I am asking is that too many things happened at once:
First, I got this infamous ABS failure caused by defect in ground wire soldering. So I decided to go diy on this one. While re-soldering I managed to tear one of those tiniest gold wires, which I had to repair but not very sure about the effectiveness.
<img src="http://passat-b5.ru/remont/abs/10.jpg"></img>
Second, I had a CV boot job done one front left wheel by a mechanic shop.
As a result, the 01203 error is gone, but 00283 error is up intermittantly (almost always).
My thinking is that either the ring/sensor is clogged with CV lube or the wire is damaged or the sensor is dead or my soldering in the controller is not working (no contact, wrong resistance etc.). Thus, I really need as much diagram as possible. I would buy the manual, but I live 10 time zones away from the supplier which makes the purchase quite complicated.
kgiessler
04-18-2013 03:56 AM
'00 Santorin S4
03-14-2004 04:12 PM
SLAB
12-13-2003 06:55 PM
Andy N
04-12-2002 06:57 AM
