Message for PaulW. Thanks a bunch.
A while ago I had an electrical problem where I lose lights, turn signal lights etc... and you suggested that the ignition switch may be the problem since you had a similar issue. You were right with the exception that it wasn't only the ignition swith but also a another part of the the ignition ensemble but mainly it was the ignition switch that led to all of the electrical problems. All is fixed now cost about $350 to get it going. I wanted to thank you for ur help.
If anyone has similar problem please contact me for solution. (I do not do any repair but I can tell you what went wrong and the part u may need to fix problem.)
Thanks Paul,
SAL
Thanks Paul,
SAL
