More detailed instructions on replacing flasher relay?
Hi folks:
Looks like the flasher relay is acting up.
I've found numerous posts of this topic, but wasn't able to find any detailed instructions, other than what I clipped below.
1) Remove the trim around the switch and cupholder. Gently.
2) Grab switch with needle nose pliers.
3) Pull hard.
4) Disconnect wiring harness.
5) Reassemble with new flasher
Can anyone provide more details?
Ok, I got the plastic trim off around the flasher/cup holder and I see the emergency flasher switch and it's receptacle.
So, do I grab the receptacle and simply pull hard?
Thanks!
3) Pull hard.
Thanks!
JMBlur
04-01-2008 02:05 PM
VikingDiesel
17
03-23-2008 11:45 AM
