motor/transmisson mount replacement?
search trans replacement - it'll give u an idea ... not easy .... >>>
u would have to jack up the trans to get the trans mounts out .... and I think u would have to jack the engine up to get the engine mounts out .... probably have to pull the subframe ....but I am not sure ... this is a job cause to pull the subframe u gotta disconnect the suspension components ... Bentley should detail it out as would some technical postings ..... just search and u will find .....
defintely doable. Sound like tranny mounts are pretty easy...
here's the the job in a nutshell (penned by Piggie):
You'll need a 10mm socket, 13mm socket, 16mm wrench; 15mm socket, 17mm wrench, if you're running RS4's.
-remove a 10mm bolt from each heat shield side of the trans mount brackets.
-remove the 16mm head bolt from the trans mount
-remove the 13mm head bolts from the underside of the trans mounts
-jack up the tranny to remove the mounts
-reinstall..
Engine mounts are trickier, and require lifting the engine, somehow. Most prefer to do this w/a cherry picker, but i think some have tried jacking from below--but that poses a risk of damaging to the oil pan.
I'll be doing both of these jobs as soon as I can find some time. Let us know if you learn anything special about them.<ul><li><a href="https://forums.audiworld.com/s4/msgs/1945094.phtml">Engine mount DIY</a></li></ul>
-reinstall..
RallyVermont
09-13-2008 08:33 PM
nadrealista
05-08-2007 06:37 AM
Nate (ETKA+Scumbag)
03-27-2007 04:37 AM
thrash
11-05-2006 04:55 PM
