Multiple cels is my ecu a goner?
I replaced the auxiliary water pump on my wife's 2001 2.7t quattro a6. It was leaking and dripping onto the reference sensor I assume causing the speedometer to quit working. The car ran fine but smokes a little under the hood but ill get to those repairs later. So during the repair I had the negative terminal disconnected 100% of the time. I had the hood propped open with my tool kit to keep from squishing all the items I had removed while it started to rain. Well it rained about 3 inches and the maf was open to the air. Possible splashes inside. I was worried but I dried everything I could. Didn't touch the maf though. Onward I finished the install. Replaced the damaged vacumn lines and went to crank the car and im getting 8 error codes in the engine. Epc light... abs light... car drives like crap.. I cleaned the maf but that didn't help. The car runs the same with or without the maf . without an educated guess my next assumption is to replace the maf. But im wondering mt my ecu went poop on me somehow.
Here's the codes... excuse the shareware im waiting until after christmas to buyba Ross tech. I borrowed a friends cable. I tried to decode them and I have searched around in all of these but I haven't found a exact similarity.
ENGINE------------------------------------------
VCDS-Lite Version: Release 1.1
Tuesday, 25 October 2011, 19:57:44.
Control Module Part Number: 4B0 907 551 T
Component and/or Version: 2.7l V6/5VT G 0002
Software Coding: 06752
Work Shop Code: WSC 02325
VCID: 351DA2D71C4F
Additional Info: WAUED64B91N165930 AUZ7Z0A1882906
8 Faults Found:
16490 - Manifold / Barometric Pressure Sensor (G71) / (F96): Implausible Signal
P0106 - 35-00 - -
16621 - Shareware Version. To Decode all DTCs
P0237 - 35-00 - Please Register/Activate
Turbo/Super Boost sensor A low input
18321 - Shareware Version. To Decode all DTCs ----Description
Brake servo pressure sensor - short to ground
Cause
Wiring short to ground, brake servo pressure sensor
P1913 - 35-00 - Please Register/Activate
16497 - Intake Air Temp. Sensor (G42): Signal too High
P0113 - 35-00 - -
17800 - Shareware Version. To Decode all DTCs
P1392 - 35-00 - Please Register/Activate - Cam position sensor
17746 - Shareware Version. To Decode all DTCs
P1338 - 35-00 - Please Register/Activate ---Camshaft Pos.Sensor,Bank1 Open Circ./Short to B+.
18041 - Accelerator Position Sensor 2 (G185): Signal too Low
P1633 - 35-00 - -
16486 - Shareware Version. To Decode all DTCs -------Mass air flow sensor
P0102 - 35-00 - Please Register/Activate
abs------------------------------------------------
Tuesday, 25 October 2011, 20:05:06.
Control Module Part Number: 8D0 907 389 E
Component and/or Version: ABS/ESP allrad D56
Software Coding: 06397
VCID: 351DA2D71C4F
2 Faults Found:
18265 - Load Signal: Error Message from ECU
P1857 - 35-00 - -
18264 - Shareware Version. To Decode all DTCs --------Throttle/Pedal Pos.Sensor A Circ. Error Message from Engine Contr.
P1856 - 35-00 - Please Register/Activate
trans========================
Tuesday, 25 October 2011, 20:05:43.
Control Module Part Number: 4B0 927 156 DJ
Component and/or Version: AG5 01V 2.7l5VT USA 1717
Software Coding: 00002
Work Shop Code: WSC 00000
VCID: 729759CB2DA1
1 Fault Found:
P1857 - 35-00 - -
VCID: 351DA2D71C4F
8 Faults Found:
P0106 - 35-00 - -
Cause
P0113 - 35-00 - -
P1633 - 35-00 - -
VCID: 351DA2D71C4F
2 Faults Found:
P1857 - 35-00 - -
VCID: 729759CB2DA1
1 Fault Found:
P1857 - 35-00 - -
O.G.2
A4 (B7 Platform) Discussion
02-18-2021 07:23 AM
uble1234
14
10-23-2020 08:07 PM
