Multitronic transmission-A6
After a complete loss of drive, I had my multitronic transmission rebuilt. Changed the chain, output shaft, forward and reverse disks, cleaned and remounted.
Everything working fine now.
However I have an issue with the PRND display all lit up when driving above 60 miles/h. When I reduce speed, display returns to normal.
Any hints?
Any hints?
Hmmm there is a company that you send your cluster in and they rebuild it for cheap. They fix things you might have know were wrong. Like the gas gauge that are a common problem.
Its called BBA-Remann and heres the link for it -
http://www.bba-reman.com/catalogue/D...ledProduct=282
Unfortunately, i do not have a VAG-COM.
I have also observed that this does not happen if i am on 5th gear (the tiptronic is six speed), even if i drive at 80 mph. If I go on 6th gear, all the 123456 lights up. I need to reduce speed or downshift to get the display working normally.
beltsander TKO
Q7 MK 1 Discussion
02-05-2007 06:34 PM
ThetaTau87
02-19-2006 05:11 AM
MrWretch
11-03-2005 01:40 PM
