MY 2000 2.7T, oil leak, towards rear of engine,What am I looking at ?
Very cold temps this morning, noticed some smoke coming from the rear of the car,Oil was dripping on exhaust is my guess,
blocked breather hose. If you see the tell-tale oil-burning smoke from the exhaust, pull over, leave the engine running, and loosen (but don't remove) the oil filler cap. Listen carefully for the sound of pressurized air escaping from the oil filler hole. If you hear it, we know the issue is the breather hose.
I've had the same issue a few times (maybe 4X last year, ONLY in very cold temps). Doesn't seem to bother anything - I just need to be vigilant and watch for the tell-tale signs.
Good luck.
Good luck.
