Is my ABS sensor finished?
<center><img src="http://pictureposter.audiworld.com/39891/sensor.jpg"></center><p>Having a few promlems with the ABS light & (O) symbol on the dash display lighting up on intermitent occasions. Search throu the forums for advice.
I ve removed the nearside front sensor to clean, & found a small hole worn throu the tip would this be the fault? Ive attached a picture, what do you guys rekon?
(Im trying to get hold of a obd lead for my laptop to check the fault codes, this week)
When inserting sensors, push until they contact the ring on the CV joint, then pull back 2mm or so. I learned the hard way.
That hole isn't good, but may not be the problem.
This is brand new, in the last 3-4 weeks. You used to have to buy the complete ABS assembly, including the hydraulics. Over $2k, vs around $500.
I ve connected to the a6 with VAG Tool, Im having a few promlems, I keep getting "No Response From Controller".. although I did get connected once and it said there were no fault codes.
Im Using Release 311.2-N Vag Tool,( I tried all the others with no luck)
I used the control Module Finder and this is what happend:....
Address 01
Protocol: KW1281
Controller: 4B0 907 557 B
Component: 1.8L R4/5VT MOTR HS D03
Coding: 04002
Shop #: WSC 02325
Address 08
Protocol: KW1281
Controller: 4B0 820 043 F
Component: A6-Klimavollautomat D61
Coding: 00041
Shop #: WSC 02325
Skipping Address 15-Airbags
Address 17
Protocol: KW1281
Controller: 4B0 919 930 H
Component: C5-KOMBIINSTR. VDO D08
Coding: 05442
Shop #: WSC 00000
Address 25
Protocol: KW1281
Controller: Bitte Adress
Component: e 17 eingeben
Address 35
Protocol: KW1281
Controller:
Note: Excessive Comm Errors
Address 45
Protocol: KW1281
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 02325
Im still getting the abs light, Symbol & sound when I turn the ignition intermitently.
Any help apreaciated
Cheers
Address 01
Protocol: KW1281
Coding: 04002
Shop #: WSC 02325
Address 08
Protocol: KW1281
Coding: 00041
Shop #: WSC 02325
Address 17
Protocol: KW1281
Coding: 05442
Shop #: WSC 00000
Address 25
Protocol: KW1281
Address 35
Protocol: KW1281
Controller:
Address 45
Protocol: KW1281
Coding: 00001
Shop #: WSC 02325
Cheers
