mysterious engine problem with no fault codes!
This is all about 1998 A6 2.8 quattro, which sometimes bucks, shudders just for a second or two, ONLY in motion (while driving) and only when rpm drops below 1800. But it does not happen every time the rpm goes below 1800. It feels like a short vibration...tink,tink...but accelerating makes it's disappear for that moment. Today I have checked this car with vag-com and it found no engine fault codes. Three months ago when it first started buckling I changed the spark plugs, this shudder/buck vanished, couple weeks ago it started again. I checked the spark plugs yesterday, they had a little bit of oil on white ceramic part (insulator),metal shell (hex) and gasket,but I believe oil came because of 'poor' valve cover gasket,which I am planning to change in nearly future, although I don't think it has any impact on the vibration itself, because terminal nut, thread and firing end were dry.
Does anyone knows what the problem might be, when computer finds no fault codes?
And I would like to stress that it is somehow related to spark plugs, because when I installed new spark plugs this buck/shudder disappeared. And after three months appeared again.
Any suggestions?
Any suggestions?
ignazzio
01-28-2006 10:13 PM
