n00b help with VAG-COM lite!
I bought a USB cable from eBay, installed the driver, installed VCDS-LITE, found and saved the correct COM port.
Did an auto scan, selected Audi A6 C5 chassis and after a few minutes I get a blank result:
![](http://img227.imageshack.us/img227/3804/vagcom.jpg)
Does this mean my car currently is fault-less? Or something wrong with the connection?
When I tried to do the OBD-II, it said my car is not OBD-II compatible???
Just go into Engine and scan that module. it's unlikely you have any faults in other controllers anyway, unless you know of a specific problem in that area, in which case, scan THAT module as well.
OK I finally got everything working, can someone confirm the following link codes will work on the A6?
https://www.audiworld.com/tech/elec13.shtml
Also anyway to turn off low beam error check permanently? Currently I am running error cancellors but be great if I can remove them and run HIDs.
Thanks!
Thanks!
