Need some help with rear spoiler install
Decided to replace my Zender with another one after it was demolished in May. Waited several months for one (on backorder from Europe) and when it finally arrived at the body shop they claimed they did not get the adhesive with it. So I had LLTek send me the correct adhesive, and I am gearing up to install it myself this weekend, but no instructions are in the package.
There was a good set of instruction somewhere on this forum a couple years ago, but they seem to have vanished. I especially want to know if the double sided tape around the edges should be left alone or if it is something the body shop used instead of adhesive (in which case it has to come off.)
LLTexk is closed for the weekend, of course, so if anyone has any clues, I would be grateful<ul><li><a href="https://forums.audiworld.com/a6/msgs/381175.phtml">Here's what happened in May</a></li></ul>
Tip:
The instructions say to lay out a 1/4" bead around the perimeter of the spoiler (there's a very faint channel that the bead is laid in).
Make sure you have enough on the ends of the spoiler to hold it down, or else the ends will lift.<ul><li><a href="https://forums.audiworld.com/a6/msgs/214990.phtml">Zender Install</a></li></ul>
A bumper so high if it hit you side on, it would be over. Hope you guys have recovered since the incident. The car okay too?
Snopyro
10-02-2004 03:59 PM
mTTvee
04-11-2004 05:42 PM
