Need tranny help
c5 a6 tranny wont catch any gear but catches park. Starts and revs fine. Tranny oil pan is dented and cause the fluid to drain. Cant move the car at all. And help or advice or anything!?
It isn't going to engage any gears if there isn't any fluid. Once you remove the pan and check for internal damage you will know more. Going into park is a mechanical function. All other gears are engaged with hydraulic pressure hence your situation. Continuing to run the car with a drained transmission is only making things worse, so stop that.
sk88erguy
Audi Original "S" Cars
12
02-04-2006 03:08 PM
