new to audi, question with picture............................
hi, new to audi, got an a6 01 1.9tdi.
the car came with a malfuction on d dash. i dont know what it is.
pull code from vagcom...
has
coolant temperature sensor(replaced)
maf sensor (replaced)
then clear all the code after that.
but the warning light is still on the dash.
drived it for 2weeks now. tried to pull code again. no fault found.
the fault light come on everytime.
when i start the car. everything is fine. self check says ok.but after i step on the brake. the warning light come on.
so i thought it got to have sumthing to do with brakes
the front brake pads are placed. i just took all the wheels out and check if i forgot to plug the brake wear cable. but everything is fine down there.
here is a picture of the warning light. i dont have the manual.so dont no what is d code stand for.![](http://home.powerapple.com/attachment/201103/28/398828_1301332288z0ZQ.jpg)
any ideas???????
has
any ideas???????
has some broken lines in d lcd screen,but it looks like a butterfly in a circle...no fault code from vagcom.
also the car is done on power, has a code of turbo charger pressure sensor code immitently.
it has 110bhp. but very hard to accelerate on the 4th and 5th gear. floor the gas, nothing. but 1st and 2nd gear seems ok on power. changed maf sensor, coolant temperature sensor.
im thinking about put a MAP sensor in
any inputs will be great help
at this point i would say use a vagcom that will test all circuites ( as in flag and test each individualy) if not you will have to do a continuity test on each brake sensor or any thing related.
tried to pull codes from vagcom. no fault at all. i hv d newest version 10.6 i think. but still no fault.
