obd scanner DONT WORK
hi i recently went to go check code for my audi a6
and autozone and other mechanics count read my codes on my car
is my scanner connector not working or is it a fuse that missing
please and thank i need to know the codes on my car and no scanner work on it anymore please help
i do have one now the ross tech its new name now is vcds but its my car that wont read no scanner i tried 13 so far i need to now is there a fuse or anything else related to this problem that i can fix
did you read the other responses?
then STFA = Search The Forum Archives
If that doesn't solve your problem, go to an independent or dealer Audi shop and get them to do it for you.
You could have a bad module that's preventing you from communicating with your ECU. ABS is prime suspect, that's why 4Driver asked if you have beeping ABS lights on.
i did get a fuel pump job after that it did not work at all since
