OEM wheels
Old 08-20-2007, 09:03 AM
  #11
Tech Guru
4Driver4's Avatar
LOL
Old 08-20-2007, 09:16 AM
  #12
JimmyC83's Avatar
sounds like he means the the ebay'd B7 RS4 wheels?...
Old 08-20-2007, 09:18 AM
  #13
AudiWorld Expert
Boston Driver's Avatar
Default Those are actually not OEM wheels...
...and to answer your question, they might fit if the spokes are not too thick/deep. You should ask the wheel manufacturer/distributor if these are designed to clear the calipers on a B5 S4. That will help determine if they will fit or not. Dimensions and offset are only part of the equation...the spoke's inside contour is a major factor.
Old 08-20-2007, 09:37 AM
  #14
A6sport's Avatar
Yes...a major concern!
Old 08-20-2007, 11:21 AM
  #15
Member
Skyler@Achtuning.com's Avatar
Default You're probably going to need a spacer to clear the HP2s
I'd recommend a 15mm hubcentric H&R spacer which would put you at ET 30.
Old 08-20-2007, 11:48 AM
  #16
*C5 AVANT STYLE*'s Avatar
Hope you're not going with 20's again...
Old 08-20-2007, 12:10 PM
  #17
Just Me's Avatar
Default And spacers change offset, and offset changes steering geometry...
Up to -35mm is probably fine. beyond that I would avoid it.
plus, spacers add another part to be slightly off center, slightly weaken the mounting, etc.
I dont like them. They may work, but why play with fire?
Grant
Old 08-20-2007, 01:29 PM
  #18
Junior Member
Raudi_6 akaDeutschMF's Avatar
Default Those'd be the ones...
...luckily I live in the DC area so its easy for me to pick them up, if they would fit, Im reading though that a H&R hubcebtric spacer would help with that prob.
Old 08-20-2007, 01:32 PM
  #19
Junior Member
Default So they are OEreps?
Either way they will be an improvement form the stock wheels, and compliment the C5 with some sport and style.
Old 08-20-2007, 01:33 PM
  #20
Junior Member
Default Def not...
...Ive decided very much against it, want to be able to clear speed bumps and the rough *** roads here in DC. Besides have heard only bad things that it does to your suspension and tranny.
Quick Reply: OEM wheels
