oil cooler leak, replaced, now leaking enging oil
Friends,
Last week I had a coolant leak near the front passenger wheel on my 2000 A6 4.2. It was also time for TB. Indy diagnosed cracked/leaking oil cooler so we replaced during TB job. Got the car back yesterday and last night I noticed a large spot on the garage floor (4x6") in exactly the same place the coolant had been leaking from before, but now it seems to be engine oil.
Really nervous about this one. Taking it back in Monday to indy, (no dealer here in Wichita) and don't want to give him any more money. (TB and Oil cooler came to $2,200)
Did mechanic error or is this something else?
Greg
Greg
Could be oil from the repair that wasn't cleaned off. Best bet is to take it back to the shop where the work was done and find out where its coming from and have them show you to verify if its something they did or if its an unrelated issue to the repairs they performed.
Indy said small leak right after repair was loose pitcock on radiator. This was obviously coolant on the floor. He tightened and said he tightened oil pan bolts as well. It was later that night I noticed the engine oil on the floor.
Thanks, respect your opinion.
But what would cause leaking substance to change from coolant to engine oil when oil cooler was changed out, other than 4D4's suspision that the oil ring was pinched in new installation? I know this guy is going to deny responsibility. Hope I'm wrong.
Turns out the oil leak was not from a twisted O-ring thankfully, it was from the oil pan gasket that needs replacing. It was just dripping oil in the same spot that the coolant was dripping.
Remove the pan and clean it, straighten out the mating surfaces on the pan, use The Right Stuff to run a bead around the pan and around all the holes and install it...you have about 10-15 minutes to do this depending on how warm it is, use green or blue loctite threadlock on the bolts, and torque them to spec. Do not overtighten or you'll just have the same problems.
Supposedly the pan is good to go in half an hour or so (read the directions on the aerosol can) but I left mine to cure overnight before I put in engine oil. If you have recently changed the oil you can try to collect the drain oil in a clean pan and strain it through a paint filter before reusing it. But you might change your mind after cleaning the oil pan...the new oil tends to quickly load up with sludge and crap that has been sitting in the oil pan for years despite frequent oil changes.
SkA6Driver
16
12-04-2014 06:24 AM
ScottGo
05-13-2002 06:16 PM
