oil leak from valve cover corners
I replaced all my cam seals, plugs, tensioner seals and valve cover gaskets a few months ago. There is still oil leaking from the passenger side but I'm having trouble tracking it down.
I am finding oil on the underneath of the cam housing at the lower corners. At the rear, it's dripping from there onto the exhaust. At the front, I find fresh oil on the underneath of the timing belt cover, running down onto the 2 coolant hoses that attach to the block in that area. The rear end of the block is dry - nothing seems to be leaking form the cam cap or chain tensioner seals. At the front, my exhaust cam seal seems to be dry, as is the inside of the upper timing belt cover.
So it seems to me it's leaking from the 2 lower corners of the valve cover gasket, and running back inwards along the bottom instead of dripping off the edge of the housing. Does that sound plausible?
When you replaced the cam/valve cover gaskets did you use black RTV and let it set up for at least 24 hours prior to starting the engine? If not then that's the most likely source of your leak.
Replace the valve cover gaskets and allow the RTV to set up. Don't over tighten the valve cover nuts either.
I have another gasket so I will go ahead and change it again and wait for the 24 hours this time
Yeah, the first time I did it I thought a few hours was enough and the oil just kept leaking out. I re-did the work and let it sit for the recommended 24 hours and not a drop since. Smells better in the cabin as well.
![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
But I suppose I would be if I just did the work properly in the first place!
You have any luck selling your car yet btw?
Yes, I did get it sold and am now looking for an A8L. I won't make some of the mistakes I made when I bought the A6. Older and wiser but hey, I have lots of neat new tools.
Oh yes, you will love the way it DOESN'T smell inside. I changed the cabin air filter just to be sure.
pull that cover off and use a mirror and see if its maybe the cam seal. Could just be the cover didnt seal well and you need to redo the valve cover and make sure to use enough silicone on the corner, and that it is perfectly clean and givin some time, few hours, to setup. Overnight is way overkill. Most black RTV is good to go after about an hour.
I think I'll let the RTV go overnight anyway, I don't need to drive the car and I'll no nuts if the next thing I do doesn't fix it!
divil, let that RTV cure for 24 hours! There's a reson for that recommendation by lots of folks besides me. The maker of the product for one, which says 1 to set 24 to cure. You will be happy with the result.
