Oil Leak. Very small dot of oil after driving
anyone know what it would cost to fix a leak like this? from looking under the car it seems to be coming out from just behind the plastic cover under the front of the car. from bottom of the engine. will it get worse in the near future? I wanted to get a 2007 4.2 sometime in the next 6 months. should i get it sooner if possible?
Thanks,
Drew
02 a6 2.7t
Thanks,
Drew
02 a6 2.7t
About $3.99, if it is a weeping rotary shaft seal, for a bottle of engine snake oil. This treatment
stopped a weeping rear main seal on my 2.7T. Of course you could opt to replace the seal, rear main at about $800. maybe?
could also be a rear main seal, had leak in almost similar area...........
first shop thought it was the upper oil pan, took it in to get it fixed, turned out to be rear main seal. $1,600.00
I find little drops not worth worry. 2 Many Big Thing$ on these will >
cheap shot ...cold **** ....and bitch slap you all to often enough ..... save ur strength, $, and nerves for the big battles.
