Oil leaks
Hi guys,
I've got oil leaks on my engine. When I take off the belly pan, I see some oil on the middle of the belly pan and on the bottom part of the engine. Is it possible that the leak is coming from the Valve cover gasket or the Cam cover gasket? because I don't smell any burning oil.
Is there any other common known part that can
make oil leaks?
Thanks so much
make oil leaks?
Thanks so much
yes, but I thought the symptom for those leaks is burning oil smell right?
Can you post any picture of how to remove those seals for 2.7T engine?
thanks
thanks
<ul><li><a href="https://forums.audiworld.com/a6/msgs/360001.phtml">https://forums.audiworld.com/a6/msgs/360001.phtml</a></li></ul>
