Ok, C/O's vs. separate spring/shock...which one avoids the
axle issue best. I want to lose 1" to put me at 25 1/4 and still throw gear and dogs and guys in back.
Any input ?
It'd be the HR Sport/Koni option for separates, and the HR C/O's.
Any input ?
AudiWorld Expert
IIRC, the grooved bilsteins were the culprit of the axle rubbing issue. What you should really consider is cost (the coilovers are more expensive), and the characteristics you are seeking.
Coilovers can lower the car, but not sacrifice as much in ride comfort. Firm, but not stiff. Lowering springs with sport or HD shocks are stiff, and more harsh than the coilovers.
I went with Bilstein H&R sport setup, ride was good, firm/stiff, but the rear of the car was about 1/2" too low for my taste. I ended up with an almost new set of H&R coilovers, and I love them!!! WIsh I went this route first, but then I would not appreciate them as much.
... will need high spring rates. KW Coilovers (I have them) are very high rate springs. Stiff ride, but it could handle a load. They may do the trick. I run at 25-7/8. I don't have any axle interference. Don't know what 25-1/4 would do.<ul><li><a href="http://www.kw-gmbh.de/e_version/gewindefahrwerke/index.php">German (home) site for KW.</a></li></ul>
most are quite stiff and designed for fast road and track use. i think the H&R streets and the bilstein PSS9's (which i had on my TT) are the only exceptions to the typical "coilover rule."
peter
peter
The spring/shock combos use a large diameter spring perch to accomodate the larger, stock diameter spring. Using a lower than stock spring perch location on any shock positions the spring perch dangerously close to the half shaft - avoid this! Because the Eibach and H&R springs are shorter and higher rate you should be able to use the stock, or even higher, perch location to achieve the ride height you desire.
Coilovers use a smaller diameter spring, and thus a smaller diameter spring perch. With most, you'd have to go very low to have an issue. In any case, if you go much lower than 25.5, you'll likely have to deal with rubbing issues.
the way to go. No axle issue, good ride and set the ride hieght for gear, dogs and guys. If that is you at the race track in your pics, get a H Sport sway bar and show them what an Avant can do.
didn't you miss that "connected" feeling ?
I mean, the car being quicker and tighter to respond to input ?
... concerned about a cushy ride, then seriously consider KW coilovers. They cost more than H&R, but the quality is there. Stainless steel bodies, very firm springs. Combined with H-sports, you'll be a monster out there.
Korgs130
Audi A3 / S3 / RS 3
04-20-2007 08:23 AM
FCOMalligan
07-12-2004 08:10 PM
simply J
04-10-2002 06:58 PM
SameerP
07-16-2001 02:26 PM
