Oops... self-canceling ring mistake
Just replaced my turn signal stalk following the excellent write-up in the forums, except... the self-canceling ring moved from its original position while I was trying to adjust the steering wheel alignment, now the MFSW controls are dead. Is there any fix other than replacing the self canceling ring?
AudiWorld Expert
...which I think shows a yellow circle when properly centered. The little indicator window is in the upper right corner of the housing (just under the red arrow on the mid-right of the picture below)
<img src="http://img.photobucket.com/albums/v739/hliu55/turn_signal_stalk/steering_column_12.jpg">
if not, move it one turn back and then an additional turn back....if the yellow doesn't show you can turn it back to (your) zero and try a turn and a half, etc.
Thanks for the suggestions. Got knocked on my butt by a virus over New Years, so I haven't had a chance to try these fixes. I'll pull it back apart this weekend.
S6 4RiNGS
Audi Original "S" Cars
09-01-2008 07:53 PM
Slivka
08-08-2000 08:06 PM
