Open or Short to Ground - Terminal 30
Ok, so I'm getting the following from the transmission module on my VAG-COM:
00688 - Supply Voltage Terminal 30
31-00 - Open or Short to Ground
Where is terminal 30? Anyone know where to start to try and track this down. I just finished replacing switch F125 on my transmission and found some broken wire next to the shifter and that got rid of a bunch of errors I had. Now I'm down to this last one.
The transmission display in the console lights up but when I reset the code, it displays correctly. When I turn off the engine and re-start, the error comes back. The car is perfectly driveable but for this one error.
mohammed
99 a6 2.8q avant
97 a4 1.8tqa
mohammed
99 a6 2.8q avant
97 a4 1.8tqa
Also, referring to the Bentley, it says terminal +30 is the ground wire to the starter. I assume then, that this goes from the negative battery terminal to the starter and somewhere there is a break in this wire. Correct?
So another question. If I need to pull the ground wire on the starter to clean/re-tighten, do I need to remove the front bumper/condenser/generator or can I access this wire as is?
Thanks!
mohammed
99 a6 2.8q avant
97 1.8tqa
Well, after some more searching online, I realize that I will probably have to take the nose of the car off to get to the generator and starter terminals.
I guess it'll have to wait until some weekend when I have time to do this. In the meantime, I'll try and clean the battery grounds.
mohammed
99 a6 2.8q avant
97 a4 1.8tqa
mohammed
99 a6 2.8q avant
97 a4 1.8tqa
Godfather | Jay
10-19-2008 12:34 PM
