Over half gallon of brake fluid flushed and brakes bled..The pedal isnt as rock solid
as I expected.
Now I havnt had brakes bled in my cars for a while, my bikes get the service every year so may be I am expecting the same rock solid feel. But, even when brakes are cold the pedal has decent bite but as I press harder to brake harder, I am able to press the pedal more and more. I expected it to have a "stop" point and then braking power to be related to pedal pressure.
We used a suction cup for bleeding the brakes, did not use the "press the pedal" methode.
Here is a sample of the dirty fluid:
<img src="http://www.pbase.com/kam1996/image/77273256.jpg">
the car? Because of neglect, you now need to overhaul the calipers and MC, rebleed the system. Should be bled once a year, just like your bikes. Audi says 2 yrs. absolute max.
Audi recommend 2 years, for sure. And after 4 years its certainly overdue. However, damage to calipers and master cylinder? Possible but unlikely. Your spongy feel is probably now due to the relatively new pads. They'll take a couple of hundred miles of gentle bedding in before the feel is back to optimum.
Is this the same Bernie who told me its crazy to change the P/S fluid after 6 years?
No new parts needed unless you have a torn boot. Blow the piston out of the front caliper with air, catching it with a stick across the caliper ears. Rear caliper pistons unscrew from the E-brake actuators. Clean all internal parts, seals and boots in IPA (rubbing alcohol). Clean and relube caliper guide pins. The piston of a good caliper can be pushed into its bore with finger pressure, the test for your current condition.
tonight when I go to work. I can take an hour break and go bed the brakes in at 2:00 in the morning when there is no traffic anywhere..
