p0300 code
p0300 code
I am getting a p0300 code (random mis-fire), but in looking in other peoples threads that get this code they usually get a specific cylinder code as well. This is just a generic code. The car is running like crap and I can feel the mis-firing. I changed all the spark plugs and bought a new ignition coil but I am beginning to question if this is really the issue since I am not getting a specific cylinder code. Anyone have any input?
I guess the mass airflow sensor could be an issue as well as the ignition control unit....but I dont know how to test them to know if they are the problem
Its not a VAG-COM that I am using, its a generic reader but reads all the codes. I have not tried running with the MAF sensor unplugged. With that unplugged wouldnt the car misfire anyway?
thanks makav3li, I will try that in the morning. Since I was gunna break down and bring the car into the shop tomorrow, thats a quick and easy test first. I will let you know how it works out.
you were totally right. I brought it to someone I trust more and it took him no time at all to figure out that it is actually one of the ICM's.
We knew which cylinder was misfiring by looking at the spark plugs. All we did was switch the ICM's around and BAM the misfire moved to a different cylinder. PROMLEM SOLVED! The part is on order now ($80 after market ICM instead of likly a $1500 ECU install, reflash, and whatever other bull**** that guy made up)
Thanks a lot for your help guys
Martin K
03-26-2019 03:27 PM
duodallas
VAG-COM Discussion
05-09-2006 04:37 PM
kkii9
09-23-2005 10:50 AM
VAP
12v V6 Discussion
03-26-2004 02:12 PM
