p0341
Old 02-14-2013, 11:21 AM
chrisbob's Avatar
Default p0341
Hi all, my 2000 A6 2.8L is running like crap! I'm getting the p0341 code along with miss fire codes. I bought a new cam sensor and it did nothing. Checked voltage at the sensor connection. 4.8v with the car off. Checked the reluctor wheel. I could see no damage. Funny thing, I was looking at codes and symptoms on the OBD site & my symptoms are identical to code p0340 but I haven't ever gotten that code. Any ideas what else it could be?
Old 02-14-2013, 01:17 PM
Tech Guru
4Driver4's Avatar
I don't even know what the codes are!
Old 02-14-2013, 02:27 PM
chrisbob's Avatar
Then you probably are not the one to answer my question
Old 02-14-2013, 02:40 PM
jcman's Avatar
Default It is what it is, and nothing else
If your code is this: P0341 or 16725
Camshaft Position Sensor "A" Circuit Range/Performance Bank 1
or Single Sensor
G40 - Camshaft Position (CMP) Sensor
Camshaft adjustment servicing
Camshaft Position (CMP) sensor checking
Ignition components removing and installing
Then that is what your dealing with, STF the code.
Old 02-14-2013, 02:49 PM
chrisbob's Avatar
What does STF the code mean?
Old 02-14-2013, 02:52 PM
jcman's Avatar
Default Easy
Search the forums
Old 02-14-2013, 03:07 PM
chrisbob's Avatar
I did search before I posted but here I go again...........
Old 02-14-2013, 03:28 PM
chrisbob's Avatar
Did I maybe skip a tooth on my timing belt? That is all I can come up with.
Old 02-14-2013, 03:41 PM
chrisbob's Avatar
Sorry to 4Driver4. I may have misunderstood what you were saying
Old 02-15-2013, 05:12 AM
chrisbob's Avatar
Anyone else out there with any ideas? Not ready to spend $200 to have it towed to somewhere so they can charge me $100 to figure out the problem.......or not. Guys, I'm not stupid just not a machanic. So anything HELPFUL would be nice. Thanks in advance.
Quick Reply: p0341
