p0341
Old 02-15-2013, 02:05 PM
  #21
joshe8695@yahoo.com's Avatar
Originally Posted by jcman
I'm glad you were able to resolve it, however you mentioned nothing about a cps code outside of your miss-fires and related codes?
Did we miss something on that post.
In post #13 I stated I had code P0341 just like the OP. Intake cam was off a tooth.
Old 02-15-2013, 02:28 PM
  #22
jcman's Avatar
#13 where?
I was refering to the thread you started with no cps code https://www.audiworld.com/forums/sho....php?t=2842003
Old 02-15-2013, 03:33 PM
  #23
#13 where?
Ok gotcha. Ill start from the begining. I bought this A6 from a guy that said he just replaced a cam adjuster. Pulled codes. P0341, cyl 5, and 6 misfires. I start by swapping CPS. No difference. Swapped plugs, wires, injectors. No difference. I took off the valve cover to find intake cam timing off. Corrected it. No more code P0341. Talked to a tech who once had a similar problems. He said a valve might be slightly bent causing the low speed misfire. Probably caused by incorrect cam timing. So I took off the head and found #5 middle valve bent. Sorry I left out the code in the other thread. At the time I didnt have the code, and didn't put two and two together.
Old 02-15-2013, 05:21 PM
  #24
Ok then. OP I would check cam timing, and do a leakdown test on the misfiring cylinders.
Old 02-16-2013, 06:27 PM
  #25
Looks like I was in Major ***** Mode yesterday and should of not even been here with that sort of reading into the Red attitude.
I had a real big blow-out with an account I dropped 3yrs ago who wants me to validate & flip a 5yr extended warranty that I sold him in 09 on a 10hp refrig compressor that his latest service company screwed-up, now he has a problem with the agreed $150 transfer fee to me to release the claim on a $6,500 warranty credit for him, so now I'm the bad guy because the fooking birds sing about that guy. Venting venting venting, sorry.
Your points are valid and with good cause.
No big deal. I look forward to your advice in the future.
Old 02-17-2013, 06:32 AM
  #26
chrisbob's Avatar
Hijack anyone?
Old 02-17-2013, 07:13 AM
  #27
Huskerbob's Avatar
Default code P0340/P0341 ???
Originally Posted by chrisbob
Hijack anyone?
So have you done anything yet?
If it is your cam position sensor/s you will need to make sure they are properly positioned like Sloop indicated.
If you think it's a cam chain deal like josh talked about you will need to pull the covers and count chain rollers.
If you are not able to do the work you will have to get it to the shop.
Old 02-18-2013, 04:15 AM
  #28
chrisbob's Avatar
Originally Posted by SloopJohnB@mac.com
It's possible but much more likely the CPS was improperly installed. Take it out and look at it...the little tit has to fit the cam.
Not sure about this part. All I see when I look behind the CPS is a metal cup with a 1" wide slot in it and a nut which bolts it to the cam. It seems kinda foolproof. Could we be talking about different engines or an I just a moron and can't see the obvious. That is a very good possibility because my wife says so all the time.
Old 02-23-2013, 05:48 AM
  #29
Huskerbob's Avatar
Default CPS
If you haven't got it yet you need to make sure the little tab on the CPS goes into the slot. (If I recall correctly every wife thinks every husband is a moron, sometimes, so you're in the club.)
toothandnail
10-21-2010 05:53 AM
kday
Audi 100 / A6 (C4 Platform)
01-13-2007 08:07 AM
Mr. Head
VAG-COM Discussion
11-21-2003 12:38 PM
Bruce M
09-21-2003 05:42 PM
808Guy
08-26-2002 01:03 PM
Quick Reply: p0341
