P0420 Bank 1 Efficiency Below Threshold
#12
I looked underneath the car and tapped on the Cat and it didn't rattle. I noticed that there's only one O2 sensor for each Cat. On the driver side, the O2 sensor is somewhat mounted sideways (right side of the Cat if your lying down facing towards the front end) and on the passenger side is mounted on the top of the Cat.
thank you for your insights...
#15
Find yourself friendly tuner shop who will help you diagnose the issue. Mine replaced the O2 sensors, and said if the exact same codes came up they would put my old one's and go to the next step/option.
#16
Efficiency is calculated based on the delta between S1 (front) and S2 (rear) sensor. The best test is to swap the B1 and B2 rear sensors and see if the problem moves.
#17
I found few pictures from Autozone's website. It shows where the O2 sensors are located.
One O2 sensor (passenger side) is located near the head gasket area mounted right after the the exhaust manifold under the hood. The other O2 sensor (passenger side) is underneath the car right before the cat. Please correct me if I'm wrong.
I might tackle replacing the the O2 sensor first than the cat...don't know which one yet...but, it's the cheapiest route...
thanks
thanks
#19
you can try swapping o2s but id say if you can pull up a vag com on any decent scanner and see how your pre and post o2s are switching on a graph if their about the same then your cats most likely bad
Popsakadog84
2.0T FSI Discussion
04-02-2019 10:19 AM
Ste4lth
12-16-2018 07:53 AM
john q
23
06-06-2016 08:22 PM
GeTTin
01-16-2001 04:35 AM
