P0604 Internal Control Module Random Access Memory (RAM) Error
I have a 2002 A6 with the 2.7t engine with about 135k. When I drive with the cruise control on the engine stalls and goes into limp mode. The ABS/traction control/check engine lights come on. When I pulled the codes I got a p0604. It only dies when I use the cruise control and do not have my foot on the accelerator.
What do I need to check?
Do I have a bad ecu?
If a bad ecu can I swap it out without taking it to a shop or dealer?
Thanks for the help.
According to the Bentley manual, the only fix for that code is to replace the ECU.
You may have Immobilizer Generation 2 or Immobilizer Generation 3. In either case, you will need to consider the effects of such when replacing the ECU.
Immobilizer - Ross-Tech Wiki
You may be able to have the ECU repaired. You can google audi ecu repair.
Audi a3 2litre s tronic
Audi a3 s tronic, I'm getting the code 18258? Can anybody help, when I eccelerate its stutters, misfires is this causing the issue? Any help is appreciated
I am new in this forum. My name is Rafael Butner. Hope you all fine. I have some questions about this forum. Question is given below:
https://www.audiworld.com/forums/a6-s6-c5-platform-discussion-7/under-carriage-gosloto-engine-lunchtime-oil-pan-wash-2920346/
My question is about this thread. If anyone has information about this thread. Please quote me and solve my problem. I am very confused about that.
Chuck-S4
Want To Buy - Archive (NO NEW POSTS HERE)
07-11-2017 08:06 PM
Jim Clark
05-17-2006 04:19 PM
JJimbo
02-27-2004 06:29 PM
Scourge
01-24-2002 06:50 PM
