Paging the Audi Gods, if I get OEM drilled A8 front rotors for my A6, do I necessarily have to buy
the TT caliper brackets? or I can get away using the A6 stock brake parts? I found a pair of OEM A8 on ebay. TIA<ul><li><a href="http://cgi.ebay.com/ebaymotors/AUDI-A8-A6-A4-DRILLED-ZIMMERMANN-FRONT-BRAKE-ROTORS_W0QQcmdZViewItemQQcategoryZ33564QQihZ016QQi temZ260112651138QQrdZ1QQsspagenameZWDVW">Clicky</a></li></ul>
Well, I was just looking for OEM rotors on ebay, and I saw those. Thats all. =)
Would I really have to get the TT caliper brackets if I get the A8 rotors?
I've not done the upgrade, but...
I presume that you need the TT caliper brackets to locate the caliper further from the hub center to accomodate the larger dia. A8 rotors.
A8 rotors = 312mm
A6 rotors = 288mm
Have you read the tech article on the subject?
<a href="https://www.audiworld.com/tech/wheel1.shtml">Resources-->Tech Articles-->Tires/Brakes/Suspension-->A8 Brakes for other Audi Applications</a>
A8 rotors = 312mm
A6 rotors = 288mm
Casablanca Avant
07-13-2007 10:41 AM
berlina
Audi 100 / A6 (C4 Platform)
12-22-2004 09:08 AM
bugzy SoCalEuro.com
03-15-2004 09:22 AM
