Paging Just Me (trans fluid question)
I tried going to the Exxon Mobil (Esso) site to look up my fluid, but it confused the hell out of me. Are there any places that sell it besides the manufacturer? TIA
Why use some other brand to save $20? when the danger of getting the wrong stuff could cost you a transmission.
based parts suppliers sell it (also comes packaged under the Febi brand name).<ul><li><a href="http://www.worldpac.com/msds/WP_103.pdf">http://www.worldpac.com/msds/WP_103.pdf</a</li></ul>
nor heard of the Esso fluid with the part number that ZF quotes in their literature being sold anywhere in North America. YOu can get it on-line for somewhere south of $20 per liter, while at the dealer it may run closer to $25 per liter, depending on the dealer of course. A VW dealer may have it for less (the B5 Passats, among others, use this same fluid).
the ZF website. IIRC, I looked into getting the Esso fluid way back when and drum quantities were the smallest size (unless you went the Audi fluid route). Good luck and I appreciate your concern about getting the correct fluid. That is why the Pentosin lists the Audi part number in the MSDS that I posted the link for.
Just note that ZF does NOT mention Pentosin as a supplier on their website. They only mention ESSO.
Apparently, Penstosin supplies Audi..
I cant argue, although I'm a bit uncertain as to why the disparity.......
Good info.
BTW, I'd just buy the audi stuff from an OEM supplier (e.g.: nto the parts counter)
Grant
Good info.
Grant
printed on it, but the bottle said Pentosin ATF-1. It would be interesting to know who makes the ATF fluid for BMW, Mercedes, Jag, Porsche, etc - as they all use ZF trannys that call for the same Esso part number. Perhaps the Audi fluid made by Pentosin is better than the Esso stuff - the Pentosin stuff is a synthetic fluid - don't know about the Esso stuff. Could be the reason why Audi calls the fluid lifetime and ZF says it needs to be changed. Not that I am advocating not changing the fluid - I changed mine. I would like to know the details on why the Esso stuff isn't sold and why Audi would spec the Pentosin stuff while the tranny manufacturer would spec something different. Must come down to $ in the end.
