Parktronic Help - Vag Related
I am thinking one of my sensors it on thr fritz. It gives me a solid beep anytime I put in reverse and it makes other odd sounds. Is anyone familiar with how to research this using vag-com?
I have gotten as far as 76-ParkAssist then what should I do? Just pull fault codes?
I have not actually used the system just the online one.
Thanks
Thanks
AudiWorld Expert
..the back of the car is like a magnet for dirt/grime, so just use a wet cloth to wipe the sensors, and make sure they are dry (yes, a water drop will trigger the proximity sensor).
If that fails, then look at address 76 and look at fault codes. If a sensor has failed, VAG COM will tell you exactly which one (driver side outer, driver side inner, passenger side inner, passenger side outer).
Good luck!
Good luck!
ImolaPR
06-28-2004 10:10 AM
Milpitas2.7T
12-04-2002 09:07 PM
