Phatbox install - Ultimate failure
Old 02-18-2005, 05:30 AM
  #11
TeddyBGame's Avatar
Default ditto...what he said. These are the parts you need. It's an install "failure"...not a...
functionality failure. You have yet you install the pbox or configure it.
Good luck!
-ted
  #12
TeddyBGame's Avatar
or...you can you my pin removal tools...see sig.
Old 02-18-2005, 05:33 AM
  #13
StoneMan's Avatar
Oh man! I feel for you. Almost had the trifecta in play there!
Old 02-18-2005, 05:39 AM
  #14
TeddyBGame's Avatar
Default Also...see my sig for my 84 pix...you need to slide out the purple locking bar in the...
<center><img src="http://www.vwnavi.com/vwnavi/photos/albums/userpics/Slide2f.JPG"></center><p>20 pin connector. See pix.
good luck!
-ted
PS: I wish I could've helped you prevent this scenario. I feel bad for not briefing you on how to install these pins.
Old 02-18-2005, 05:41 AM
  #15
PaulW's Avatar
Default Just buy a new 20 pin connector and re insert the wires
It is almost impossible to figure out which side is right side up or upside down the first time.....I've done that before also.
  #16
absolutcq20v's Avatar
Default Bollocks!! I forgot to warn you about ham-fisted installers!! :P
As tremor mentioned, you should be able to find those crimp ends...somewhere(?). Worse case scenario is resplicing a new connector into your harness, but lets hope thats not necessary.
Good luck, don't let it deter you from future work...just take your time and don't get antsy, pretend you're doing surgery on a pet or child. :P
Old 02-18-2005, 05:46 AM
  #17
TeddyBGame's Avatar
Default That's a lot of pins/wires to relocate. His 20 pin connector has 8 open slots...
...I assume he knows where each pin goes (i.e. location #13-20). I hope the cable came with those specifics. If not...then that makes the process a lot harder.
-ted
Old 02-18-2005, 06:07 AM
  #18
RLG
RLG's Avatar
Guess I should have said &gt; 2002. I wasn't totally sure - thanks.
Old 02-18-2005, 06:17 AM
  #19
RLG
RLG's Avatar
Default You know how it goes - knew that, didn't have the tools, and figured: "I can make it work"
Famous last words.
It's the story of my life. Trying to make due with the improper tools, then spending like 10 times the amount of time on the same job fixing the problems caused by using them. Oh well, makes for stories on occassion, I guess.
I actually read that post, Teddy, about the pin removal tools. I was thinking about them and how I wished I had some as I picked up the pair of wire cutters and literally broke the plug apart (since I had a replacement) socket by socket. 3 hours later, I had blistered fingers, jacked wires, missing pins, and a busted set of glasses.
Oh well, my eyes were already blurry from the tears or frustration, so the glasses weren't really necessary anyhow! FUN!!!
Thanks you guys....
Old 02-18-2005, 06:18 AM
  #20
RLG
RLG's Avatar
Default Music to my ears. THANKS!!
I thought I might end up having to replace the whole damn wiring set. NOT looking forward to that!!
Thanks for the info....
Quick Reply: Phatbox install - Ultimate failure
