positive side battery cable..
Leaky battery had disintegrated my positive battery cable. I need to replace it. It seems straight forward, other than I can't see where it connects to from under the hood. Does anybody have any info for this procedure? Thanks in advance.
rfark (12-18-2022)
AudiWorld Expert
I've never done this, but I would guess that there would be a connection to the alternator. Should be easy enough to do. If you can wait, I will look at the Bentley tonight.
AudiWorld Expert
Here are a couple of reference pictures for you. I looked at the Bentley Manual, and there does not appear to be any specific instructions for removing that cable harness. I would imagine that the positive lead, from teh wiring diagram, is conected to the alternator, battery, and starter, as well as the power leads under the dash.
Wiring Diargram
![Name: battery.jpg
Size: 43.8 KB](https://www.audiworld.com/forums/attachments/a6-s6-c5-platform-discussion-7/79995d1501281150-positive-side-battery-cable-battery.jpg)
Part diagram (Component #15):
![Name: batteryharness.jpg
Size: 62.7 KB](https://www.audiworld.com/forums/attachments/a6-s6-c5-platform-discussion-7/79996d1501281150-positive-side-battery-cable-batteryharness.jpg)
Note similar part number #1 but that is for the 1.8T engine in Europe. I could not find a listing for the 2.8.
Sorry I could not find anything else about removal, but I'm sure it is not easy :P
Wiring Diargram
![Name: battery.jpg
Actually, I should have mentioned the battery cable is needed for an '01 A6 2.7T, my bad. Still waiting for the cable to be shipped, hopefully soon. I'll keep everybody posted as to how and how difficult it is to swap out.
First and foremost, I want to thank Boston Driver for the wiring diagram.
The dealer told me it was a three hour job..really discouraging. It was impossible to get to the proper connections without totally disassembling many parts. I also received the wrong part from a junk yard...grrr.
Decided to repair as opposed to try to get the right part and tackle the seemingly impossible. Spliced the wire needed and connected them between two side post battery mounts with a bolt in the middle holding the two pieces together. Taped and zip tied it out of the way from any bare metal. Totally worked out beautifully.
I'll definitely be keeping an eye on that battery leakage in the future.
Glad to hear that it worked out. One favor: please try to respond in the correct place within the thread. All of your responses appear to be to yourself at the root. Check out threaded view to see what I mean. When responding to a particular post, click on "quote and reply" within that post. Thanks!
audi901988
01-19-2009 07:24 AM
das_20v
05-19-2008 03:09 AM
Jack in FL
Audi 100 / A6 (C4 Platform)
18
07-27-2003 10:46 PM
