Power Lumbar Broken? How To Access?
Old 09-25-2009, 01:38 PM
StarryTripper's Avatar
Default Power Lumbar Broken? How To Access?
My power lumbar on drivers seat has never sounded to healthy during the time that I owned the car, but it has worked
now I just hear the motor going, but nothing is moving...and it's very uncomfortable
I searched around and found info for the A4, which I tried on my A6 and it certainly does not appear to be put together the same.
Does anyone know how I can open up the seat, hopefully from the back, to get in their and repair or replace the lumbar unit?
thanks
Old 09-25-2009, 07:09 PM
radhaz's Avatar
My eBahn has a procedure for the lumbar.
remove seat (not sure that's needed)
pry cover fastening strip out of backrest trim
unclip backrest trim with clips
pull backrest trim downward and out
Old 09-26-2009, 04:30 AM
thanks
I'm confused on what "pry cover fastening strip out of backrest trim" is exactly.
I took a long, narrow flat head screwdriver and tried working my way across the top, thinking that's where the clips are
I ended hearing a horrible snap and can now see a small hole I punctured
It really seems like it's a solid piece, but I guess that's not possible
The only real movment I could seem to get was by lift up from the bottom where the courtesy floor lamp is and then out slightly, I felt something unclip and it was more loose than the passenger side was at the bottom after
But still, it was as if it was a single piece, not like how the picture shows just the back piece coming off
Old 09-26-2009, 08:47 AM
radhaz's Avatar
Maybe your seat is a bit different? Can you post a picture of it?
Old 09-26-2009, 09:41 AM
Default Pictures
I just got these with my Pre, it's alittle rainy and dark ouy and I had to scale them down to no more than 800x600, so not the best
But should be good enough
In the pics, it sure looks like it comes apart!
But as I pull between the plasticy backrest and the side leater, it's like it's just one piece
Old 09-26-2009, 10:35 AM
radhaz's Avatar
Looking at that a4 write-up, you pry the top of the cover out of the backrest. Looks like a lot of bending is in order.
http://www.a4mods.com/index.php?page...es/lumbar.html
Another illustration:
http://www.vagcat.com/p/B201/881500.png
Old 09-26-2009, 11:31 AM
radhaz's Avatar
And then I find this:
http://www.justanswer.com/questions/...at-lumbar-down
I'm not sure how the seat back comes off.
Old 09-26-2009, 11:44 AM
radhaz's Avatar
I think this is the answer:
http://tech.bentleypublishers.com/th...ssageID=273632
Old 09-29-2009, 02:03 PM
Default Good Find!
I'm gonna hopefully give that a try today
Old 09-29-2009, 02:09 PM
radhaz's Avatar
Take some pics if you can.
Good luck!
Quick Reply: Power Lumbar Broken? How To Access?
