Problem with the car need help MAF, and O2; B1,S1
VAG-COM Version: Release 409.1-S
Control Module Part Number: 4B0 907 551 L
Component and/or Version: 2.7l V6/5VT G01 0003
Software Coding: 06652
Work Shop Code: WSC 40104
13 Faults Found:
18014 - Rough Road/Engine Torque Signal from ABS: Electrical Malfunction
P1606 - 35-00 - -
17831 - Secondary Air Injection System: Bank 1: Insufficient Flow
P1423 - 35-10 - - - Intermittent
17819 - Secondary Air Injection System: Bank 2: Insufficient Flow
P1411 - 35-10 - - - Intermittent
16805 - Warm Up Catalyst: Bank 1: Efficiency Below Threshold
P0421 - 35-10 - - - Intermittent
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-00 - -
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16685 - Cylinder 1 Misfire Detected
P0301 - 35-10 - - - Intermittent
16688 - Cylinder 4 Misfire Detected
P0304 - 35-10 - - - Intermittent
17545 - Fuel Trim: Bank 1 (Add): System too Rich
P1137 - 35-10 - - - Intermittent
17547 - Fuel Trim: Bank 2 (Add): System too Rich
P1139 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
17521 - Oxygen (Lambda) Sensor: B1 S1: Internal Resistance too High
P1113 - 35-10 - - - Intermittent
17539 - Oxygen (Lambda) Sensor: B2 S1: Internal Resistance too High
P1131 - 35-10 - - - Intermittent
Control Module Part Number: 4B0 962 258 J
Component and/or Version: Central Lock/Alarm D33
Software Coding: 15981
Work Shop Code: WSC 00404
9 Faults Found:
01572 - Alarm triggered by Door Contact Switch: Passenger Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01557 - Contact Switch in Locking Cyl: Driver Side: Open (F241)
29-10 - Short to Ground - Intermittent
00955 - Key 1
09-10 - Adaptation Limit Surpassed - Intermittent
01559 - Drivers Door
58-10 - Can't Lock - Intermittent
01574 - Alarm triggered by Door Contact Switch: Right Rear
35-00 - -
13 Faults Found:
P1606 - 35-00 - -
P0102 - 35-00 - -
9 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00955 - Key 1
35-00 - -
Demoskp
Audi A3 / S3 / RS 3
06-06-2018 01:39 AM
DWP
01-24-2009 08:01 PM
