Problems with Alarm,Central Locking and Key Fobs
I have recently bought a 1999 Diesel A6 Automatic.The previous owner did say the central locking wasn't working but the doors all opened ok manually.The remotes on both key fobs didn't work either.
After reading some posts about faulty central locking I located the CCM and discovered 2 of the plugs were disconnected.I replaced them and then tried synchronizing the Key fobs as suggested on another post.It didn't seem to work though the batteries are ok as I had replaced them both.
I locked the car with the key and everything appeared ok.
However next day when i had to Unlock the Boot(with the key)and then lock it again I noticed both Indicator lights come on so i assumed alarm had set.But when I unlocked door the indicators were flashing at a high rate( the audible alarm wasn't sounding and I later discovered the speaker had been disconnected).I could not switch the alarm off and nor could I unlock the passenger doors.I had to get the carpet up as best I could without being able to open the door and remove the plugs which I had put in.The alarm stopped and the car was able to be started and driven but I still can't unlock the nearside passenger doors.
Any ideas anyone pleaase
Yes. Buy vag-com from ross-tech, it's the only way if you want to do any diagnostics yourself.
Otherwise, be prepared to spend money at an Audi dealer or independent Audi mechanic.
Thanks for that,I was going that route of self-diagnosing but cannot find where to plug it in.I have found the hole under steering wheel where it looks like it should be, but there is nothing there,have taken off panel under dash and cannot find it.As you said looks like having to go to Audi.
Yes I found the hole where it looks like it should have been as you say under steering wheel on left.The port hole was exactly that,a hole,I took off the surround so that I could look behind thinking it had somehow been pushed in but could not locate it.
I can't imagine a car not having it. Maybe someone tucked it inside to prevent rattling? I dunno...
Cant lock or unlock doors with Key FOB or with the lock button on inside of the driver side door????
S4fastaudi
08-17-2004 05:33 PM
silvertiger
02-28-2002 04:53 PM
