Last edit by: IB Advertising
- Audi A6 C6 How to Change Manual Transmission Fluid<br>Step by step instructions for do-it-yourself repairs.
Proper Manual Transmission Fluid
Check out our manual transmission service kits and fluid below!
Click HERE to order or for more information
![](http://c1552172.r72.cf0.rackcdn.com/439737_x600.jpg)
Jason
Jason
Mobil 1's product is GL-5 which is incompatible with any transmission that contains brass parts. This Audi transmission cannot use GL-5.
Check your manual to be sure but for my 6 speed O1E A4 I used the same fluid posted by Jasbon above. It's not cheap but definitively felt a big difference after changing.
Allocation of mechanical units: 6-speed Manual Transmission 01E, AWD
(2.5 Ltr.) synthetic oil, SAE 75W90 Part No.
G 052 911 A1 (container size, 0.5 liter)
G 052 911 A2 (container size, 1.0 liter)
Rear final drive 01R (1.5 Ltr.)
Gear oil G 052 145 A1 (container size, 0.5 liter)
Gear oil G 052 145 S2 (container size, 1.0 liter)
I also used the opportunity to install the dimple magnetic plug - M22X1.5X14 will find out how it works the next time I change the oil I guess![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
http://www.drainplugmagnets.com/vwandaudi.php
Thats such an old wives tale. GL-5 does not hurt brass parts. Its like the myth of green coolant eats aluminum parts, rediculous. It specifies G 005 000 - Synthetic SAE 75W90 Gear Oil. Just use somthing like mobile 1 or redline or royal purple
I believe this is correct, with some caveats. See the following. You need a GL-5 with two characteristics:
1. recent formulation to be brass safe (generally synchro-safe)
2. friction modifiers to allow synchros to work effectively
Many GL-5s are for hgih pressure, high temperature gears- great for the rear end/final drive, but are in fact too slippery to work well. Zero friction, zero synchronization.
http://www.bobistheoilguy.com/forums...=501240&page=1
Grant
Grant
Mobil on their web site specifically states that its GL-4/GL-5 gear lube is not to be used in manual transmissions specked for GL-4. The 6 speed Audi transmission calls for GL-4. Not a myth after all.
Audi Other FS: 2007 Audi RS4 black/black CCW
ilikeit
01-09-2016 09:24 AM
Jorge Vargas
09-08-2015 07:45 AM
CPLYONS
09-07-2015 07:19 PM
