Queens/Long Island (NY) Mechanic recommendations
Hey guys, does anyone have a good mechanic in the Queens/long Island Area? I need to have the timing belt service done along with replacing
Timing belt
Tensioning roller
tensioner
tensioner pivot arm
tensioner
idler
water pump
thermostat
coolant flush
Cam adjuster seals (2)
valve cover gaskets (2)
Cam seals (4)
cam caps (2)
crank seal
Serp belt
serp belt tensioner
suction pump
green check valve
I got a $500 dollar labor only estimate from a good shop in Brooklyn, is this ok? Do you know of better prices?
Also I wanted to buy the parts from Blaufergnugen, I found a kit, and I will have to add a few things. tell me what you think of the kit/ Value
http://www.blauparts.com/proddetail.asp?prod=GH21112%2DB&cat=1723<ul><l i><a href="http://www.blauparts.com/proddetail.asp?prod=GH21112%2DB&cat=1723">http ://www.blauparts.com/proddetail.asp?prod=GH21112%2DB&cat=1723</a</li></ul>
Timing belt
Tensioning roller
tensioner
tensioner pivot arm
tensioner
idler
water pump
thermostat
coolant flush
Cam seals (4)
cam caps (2)
crank seal
Serp belt
serp belt tensioner
suction pump
green check valve
The post on page two...it was from the 25th or 27th I believe. (hint: he had a horrible T-belt bearing failure courtesy of Blau...)
Audi savy, mods, race equip, tune up, gener main. etc.
Tell him Paul Bernstein suggested him.<ul><li><a href="http://www.tyrolsepsot.com">clcik</a></li></ul>
IB Adrian
21
11-25-2009 09:48 PM
dm.A4.B5
11-15-2007 10:09 AM
99 quattro
03-02-2007 01:58 PM
menta
04-22-2004 06:35 AM
