Quick Poll: Aux water pump replacement, I got an estimate of $800, what did others pay?
Argh.... 85k miles is adding up in the pocket book. Next audi, I'm getting the extended warranty. They didn't have it when I got mine.
Cheers-
Ernesto
Cheers-
Ernesto
I have the invoice in front of me...$690.15. My extended warranty kicked in squat on this repair...Though I've heard others write it was covered in their policies...;/
replacing them on the 2.7T engines around 70-100k miles.
You could replace them on the old five cylinder turbos in about 10 minutes as the pump was out in the open. On the 2.7T, the pump is _under_ the intake manifold, which requires the removal of a lot of components to get at it, and the replacement of misc. gaskets, etc. upon reassembly. Also because of the location, you are unlikely to notice the leakage until it fails catastrophically, which will strand you. On the old cars, you could easily bypass the pump to get mobile. BTDT a couple of times.
What really astounds me is that this same afterrun pump has been used for almost twenty years, and they still haven't found a good design or suitable alternative.
water pump? If so, then I guess I have to replace it. If not, and this is the same pump, I'm guessing it's still covered under warranty from the shop I had it done at.
Cheers-
Ernesto
Cheers-
Ernesto
ssaa77
S4 (B8 Platform) Discussion
21
01-19-2011 10:39 AM
