Radio removal keys...HELP Please....
<center><img src="http://www.bimmerboard.com/members/johngoga/original/keys.jpg"></center><p>Noob here...
Can you guys tell me if these are the right keys i need to remove the radio in a 2001 A6, Quattro?
What i am trying to do is change the hazard light switch since i have the famous clicking comig from it and from my understanding i have to replace that. To get that switch out do i have to remove the radio?
Thank you,
Thank you,
Remove the the face plate that covers the the hazard light switch by using 2 small flat faced screw drivers on one side and gentle pry the cover outwards.That will give you access to the hazard switch.
The hazard switch itself is held in place by 2 retaining springs on each side. You will have to use the small screw drivers and try to wedge them on each side of the switch to depress the springs so that the switch will slide out. Then it's a matter of disconnecting the connector from the switch.
Hope this helps.
Hope this helps.
Jack Wang
11-21-2002 03:48 PM
jgriff
05-06-2002 02:47 PM
