Rear Cam Seals - ?
Rear Cam Seals - ?
How to I get the rear Cam Seals out?
Is there a screw which I can use to press the new one in?
I have been using a small screw (spax - dry wall type)on the front ones, which you screw gently into the seal and it comes right out! Works like a charm. However, I am concerned about the space in the rear especially to press them in!
Re: Rear Cam Seals - ?
the rear seals are not the "donut" type. The seals that leak all the time come in a kit that includes a half-moon plastic insert and a black and blue gasket about 6 inches long. The gasket goes under the chain tensioner on the rear of the head. The valve covers must come off and there is a special tool to screw down the tensioners so you can wiggle out the old seals. Search this forum for complete writeups of this procedure.
I know that my cam adjuster seals are leaking as well as my front exhaust cam seals. However, while I am at it I was wondering how to replace the rear cam seals as well!
Any help appreciated....
To fix a leaking rear cam seal, I just need to remove the rear most cam holder and pop the seal off?
CK NYoC
12v V6 Discussion
08-22-2007 07:26 PM
Catamount90
13
01-30-2007 01:35 PM
KMU
05-24-2005 09:08 AM
